I see that the NX-454 comes with a plastic "tray". I assume you mount this, and this allows you access to change the battery.
Should I use the double-sided tape, or should I drill it in with screws to make it more secure?
...also maybe I'm being a bit paranoid, but what if someone breaks the glass, and then can hold the sensor to the contact and open the window? Yes I have glass break detectors, but not enough...yet.
Thoughts?
Thoughts?
