Oman said:
As far as the 10ms delay between bytes being sent to the PLM go - it is worse with the PLC (and the issue is now gone with the PLM). The turnaround time when dealing directly with the PLM is about 50% lower than with the PLC/SDM solution. Total uptime is significantly higher.
Jon
I did comparative stress tests with 2 different PLC's & 2 different PLM's. The PLM was not even the slightest bit faster than the PLC (even with the PLC's added layer of the SDM). You would think that there would be a big difference in performance becaused of the added layer of the SDM, but that's actually not what I saw. Unfortunately, I believe the real bottleneck is either the actual chip inside the PLM & PLC, or the programming of the chip. It's slow enough that the added layer of the SDM really doesn't seem to make any difference. At least that's what I got from my own tests. Hence the reason I decided not to add support for the PLM in LightShowMaster.
I do agree that stability is much improved in the PLM.
