Insteon not working
RandyKnight
When I had the initial problem I started this thread with, the blinking lights worked just as they should in the initial location, but I still had the phase issue and had to move them by trial and error to get things working.
SmartLabsMike
WayneW said:
I don't believe the SignaLincs do linking like the other Insteon stuff does. I believe the LEDs are on the SignaLinc strictly as a tool to help you get the first two on opposite phases. If you added a third SignaLinc, you should be able to position it where needed and power it via either phase.
Wayne is correct. The blinking during initial setup is to identify the 2 phases. After this you can plug in more and they will automatically communicate with the existing RFs.
