Irrigation Rules
nov0798
I know there used to be an example of rules posted on Elks old website in their newsletter files of how to use the M1 as an irrigation controller. I have looked on their old website, but cannot seem to find the example of the rules. Does anyone know where I can find these rules, or is someone good with writing the rules?
Stumbled across the link you are looking for
http://www.elkproducts.com/support/M1_Appl...ionexamples.htm
Perfect, Thanks. it seems difficult to find anything on their website in regards to application notes, etc. I dont know why they didnt make it easier.
I setup my sprinkler rules on my Elk similarly. Some things I did that make things better.
1) Set a counter to track when you are running your sprinkler on its automatic cycle. For example if you wanted to turn a zone on becuase you just planted something or were doing some repair work, you might want to just turn the output for that zone on and off directly rather than using rules. If you turned the output off directly, it would turn the next zone on automatically without this rule in place. If you set a counter to 1 when the automatic sprinkler runs and require that the counter is 1 for the additional zone propogation, then outputs can be turned on and off directly without the zones advancing. You need to put a line into the last zone shut off that turns the counter back to 0 when the auto cycle is finished.
2) If you use custom settings instead of writing the times directly into the rules to time your zones then I find it is easier to adjust the times at future dates. The only trick is that you have to measure it in seconds, not minutes. The first time I ran that I was like.. what the heck!!!! as the zones raced through becuase I was thinking minutes.
3) I also put a zone advance task in there. The zone advance lets you push the zone to the next zone before it is done by activating this task. This is useful if you want to zip through the zones looking for malfunctioning heads or other issues. This is a series of rules that states when task zone advance is activated and x output is on, turn x output off. You right this same rule for each zone.
4) I put a "dont sprinkle tomorrow rule" in. When I know that tomorrow is a sprinkle day but I want to block it I use this rule. It says that whenever task "don't sprinkle" is activated, set don't sprikle counter to 24. Then a separate rule counts that number down to 0 one hour at a time stating that whenever every hour and don't sprinkle counter is not equal to zero, subtract one. This counts the number down to zero over 24 hours. The rule that activates the automatic sprinkler's first zone has a line that requires that counter to be zero or it won't start the sprinklers (in addition to the days of the week and time you want to sprinkle). Don't forget to put the "and counter not equal to zero" line in or it won't stop counting down at zero but rather roll over to the dafault max number and keep counting down from there.
5) Lastly, I put in to have the keypads display whenever one of the sprinkler outputs is on by stating which zone is running.
Here's a set of irrigation rules that give me a lot a versatility. In addition to automated watering, I added a set of maintenance tools (manual irrigate) in order to walk around the yard with a keyfob and stop/start/index the zones and control a pump relay. Also, I included a task to skip irrigation for a single day (I prefer this over approach over rain sensors). And, there are a bunch of outputs to set the watering days and I use the custom fields to control the run times and adjust them for seasonal changes using the ELK RM software.
20 WHENEVER Water Full Yard (Task 1) IS ACTIVATED
AND ManIrrIndex (Counter 7) IS EQUAL TO 0
AND AutoIrrIndex (Counter 5) IS EQUAL TO 0
THEN SET AutoIrrIndex (Counter 5) TO 6
21 WHENEVER Kill Irrigation (Task 2) IS ACTIVATED
THEN SET AutoIrrIndex (Counter 5) TO 0
THEN SET ManIrrIndex (Counter 7) TO 0
THEN TURN Irrigation Pump (Out 33) OFF
THEN TURN IrrigationZone1 (Out 34) OFF
THEN TURN IrrigationZone2 (Out 35) OFF
THEN TURN IrrigationZone3 (Out 36) OFF
THEN TURN IrrigationZone4 (Out 37) OFF
THEN TURN IrrigationZone5 (Out 38) OFF
THEN TURN IrrigationZone6 (Out 39) OFF
THEN CHIRP THE OUTSIDE SIREN 2 TIMES
22 WHENEVER Irrigation Pump (Out 33) STATE IS TURNED OFF
AND AutoIrrIndex (Counter 5) IS NOT EQUAL TO 0
THEN SUBTRACT 1 FROM AutoIrrIndex (Counter 5)
23 WHENEVER AutoIrrIndex (Counter 5) CHANGES TO 6
THEN TURN IrrigationZone1 (Out 34) ON FOR WaterTime1 (Cust Set 1)
THEN TURN Irrigation Pump (Out 33) ON FOR WaterTime1 (Cust Set 1)
24 WHENEVER AutoIrrIndex (Counter 5) CHANGES TO 5
THEN TURN IrrigationZone2 (Out 35) ON FOR WaterTime2 (Cust Set 2)
THEN TURN Irrigation Pump (Out 33) ON FOR WaterTime2 (Cust Set 2)
25 WHENEVER AutoIrrIndex (Counter 5) CHANGES TO 4
THEN TURN IrrigationZone3 (Out 36) ON FOR WaterTime3 (Cust Set 3)
THEN TURN Irrigation Pump (Out 33) ON FOR WaterTime3 (Cust Set 3)
26 WHENEVER AutoIrrIndex (Counter 5) CHANGES TO 3
THEN TURN IrrigationZone4 (Out 37) ON FOR WaterTime4 (Cust Set 4)
THEN TURN Irrigation Pump (Out 33) ON FOR WaterTime4 (Cust Set 4)
27 WHENEVER AutoIrrIndex (Counter 5) CHANGES TO 2
THEN TURN IrrigationZone5 (Out 38) ON FOR WaterTime5 (Cust Set 5)
THEN TURN Irrigation Pump (Out 33) ON FOR WaterTime5 (Cust Set 5)
28 WHENEVER AutoIrrIndex (Counter 5) CHANGES TO 1
THEN TURN IrrigationZone6 (Out 39) ON FOR WaterTime6 (Cust Set 6)
THEN TURN Irrigation Pump (Out 33) ON FOR WaterTime6 (Cust Set 6)
29 WHENEVER SUNRISE
AND Auto Irrigate (Out 19) STATE IS ON
AND SkipIrrigate (Counter 6) IS EQUAL TO 0
AND Irrigate Sun (Out 12) STATE IS ON
AND THE DAY(S) OF THE WEEK IS/ARE S------
THEN ACTIVATE Water Full Yard (Task 1)
30 WHENEVER SUNRISE
AND Irrigate Mon (Out 13) STATE IS ON
AND THE DAY(S) OF THE WEEK IS/ARE -M-----
31 WHENEVER SUNRISE
AND Irrigate Tue (Out 14) STATE IS ON
AND THE DAY(S) OF THE WEEK IS/ARE --T----
32 WHENEVER SUNRISE
AND Irrigate Wed (Out 15) STATE IS ON
AND THE DAY(S) OF THE WEEK IS/ARE ---W---
33 WHENEVER SUNRISE
AND Irrigate Thu (Out 16) STATE IS ON
AND THE DAY(S) OF THE WEEK IS/ARE ----T--
34 WHENEVER SUNRISE
AND Irrigate Fri (Out 17) STATE IS ON
AND THE DAY(S) OF THE WEEK IS/ARE -----FTHEN
35 WHENEVER SUNRISE
AND Irrigate Sat (Out 18) STATE IS ON
AND THE DAY(S) OF THE WEEK IS/ARE ------S
36 WHENEVER THE TIME IS 12:00 PM
AND SkipIrrigate (Counter 6) IS GREATER THAN 0
THEN SUBTRACT 1 FROM SkipIrrigate (Counter 6)
37 WHENEVER Skip 1 Day Irr (Task 3) IS ACTIVATED
THEN ADD 1 TO SkipIrrigate (Counter 6)
38 WHENEVER Reset Skip Irr (Task 4) IS ACTIVATED
THEN SET SkipIrrigate (Counter 6) TO 0
39 WHENEVER Manual Irrigate (Task 5) IS ACTIVATED
THEN SET ManIrrIndex (Counter 7) TO 6
THEN CHIRP THE OUTSIDE SIREN 1 TIME
40 WHENEVER Manual Irr Index (Task 6) IS ACTIVATED
AND ManIrrIndex (Counter 7) IS NOT EQUAL TO 0
THEN SUBTRACT 1 FROM ManIrrIndex (Counter 7)
41 WHENEVER ManIrrIndex (Counter 7) CHANGES TO 6
42 WHENEVER ManIrrIndex (Counter 7) CHANGES TO 5
43 WHENEVER ManIrrIndex (Counter 7) CHANGES TO 4
44 WHENEVER ManIrrIndex (Counter 7) CHANGES TO 3
45 WHENEVER ManIrrIndex (Counter 7) CHANGES TO 2
46 WHENEVER ManIrrIndex (Counter 7) CHANGES TO 1
47 WHENEVER ManIrrIndex (Counter 7) CHANGES TO 0
Here are my rules with the features I posted in my earlier comments.
The first 16 rules allow for manual zone advance
Rules 18 and 19 are to disable automatic sprinkling for 24 hours
17 then 20 through 35 propogate the zones through as one shuts off the next turns on
36 shuts the system down
37 starts the automatic sprinkling.
1 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Rt Sml Gar MPR (Out 32) STATE IS ON
THEN TURN Rt Sml Gar MPR (Out 32) OFF
2 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Rt Prop Ln Rotor (Out 31) STATE IS ON
THEN TURN Rt Prop Ln Rotor (Out 31) OFF
3 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Rt of Dr Rot Ner (Out 30) STATE IS ON
THEN TURN Rt of Dr Rot Ner (Out 30) OFF
4 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Rt of Dr Rot Far (Out 29) STATE IS ON
THEN TURN Rt of Dr Rot Far (Out 29) OFF
5 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Bet Garage Beds (Out 28) STATE IS ON
THEN TURN Bet Garage Beds (Out 28) OFF
6 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Frt of Hs MPR (Out 27) STATE IS ON
THEN TURN Frt of Hs MPR (Out 27) OFF
7 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Rt Side Beds (Out 26) STATE IS ON
THEN TURN Rt Side Beds (Out 26) OFF
8 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Lt Side Beds (Out 25) STATE IS ON
THEN TURN Lt Side Beds (Out 25) OFF
9 WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Bubbler (Out 24) STATE IS ON
THEN TURN Bubbler (Out 24) OFF
10WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Frt @ St Bed (Out 23) STATE IS ON
THEN TURN Frt @ St Bed (Out 23) OFF
11WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Lt of Hse Rot (Out 22) STATE IS ON
THEN TURN Lt of Hse Rot (Out 22) OFF
12WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Lt of Dr Rot Ner (Out 21) STATE IS ON
THEN TURN Lt of Dr Rot Ner (Out 21) OFF
13WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Lt of Dr Rot Far (Out 20) STATE IS ON
THEN TURN Lt of Dr Rot Far (Out 20) OFF
14WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Bk Yrd Rotor (Out 19) STATE IS ON
THEN TURN Bk Yrd Rotor (Out 19) OFF
15WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Bk Yrd Bed (Out 18) STATE IS ON
THEN TURN Bk Yrd Bed (Out 18) OFF
16WHENEVER Zone Advance (Task 2) IS ACTIVATED
AND Rt of Hse Rot (Out 17) STATE IS ON
THEN TURN Rt of Hse Rot (Out 17) OFF
17WHENEVER Sprinkle Yard (Task 1) IS ACTIVATED
THEN TURN Rt of Hse Rot (Out 17) ON FOR R o Hse Rot (Cust Set 1)
THEN DISPLAY "Rt of Hs Rot" IN Main House (Area 1) INDEFINITELY, [*] CLEARS
THEN SET sprinkler (Counter 2) TO 1
18WHENEVER Don't Sprinkle (Task 10) IS ACTIVATED
THEN SET don't sprink (Counter 5) TO 24
19WHENEVER EVERY 1 HOUR
AND don't sprink (Counter 5) IS NOT EQUAL TO 0
THEN SUBTRACT 1 FROM don't sprink (Counter 5)
20WHENEVER Rt of Hse Rot (Out 17) STATE IS TURNED OFF
AND sprinkler (Counter 2) IS EQUAL TO 1
THEN TURN Bk Yrd Bed (Out 18) ON FOR Bk Yrd Beds (Cust Set 2)
THEN DISPLAY "Bk Yrd Bed" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 21WHENEVER Bk Yrd Bed (Out 18) STATE IS TURNED OFF
THEN TURN Bk Yrd Rotor (Out 19) ON FOR Bk Yrd Rot (Cust Set 3)
THEN DISPLAY "Bk Yrd Rot" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 22WHENEVER Bk Yrd Rotor (Out 19) STATE IS TURNED OFF
THEN TURN Lt of Dr Rot Far (Out 20) ON FOR L o Dr Rot F (Cust Set 4)
THEN DISPLAY "Lt of Dr Rot Far" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 23WHENEVER Lt of Dr Rot Far (Out 20) STATE IS TURNED OFF
THEN TURN Lt of Dr Rot Ner (Out 21) ON FOR L o Dr Rot N (Cust Set 5)
THEN DISPLAY "Lt of Dr Rot Ner" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 24WHENEVER Lt of Dr Rot Ner (Out 21) STATE IS TURNED OFF
THEN TURN Lt of Hse Rot (Out 22) ON FOR L o Hse Rot (Cust Set 6)
THEN DISPLAY "Lt of Hse Rot" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 25WHENEVER Lt of Hse Rot (Out 22) STATE IS TURNED OFF
THEN TURN Frt @ St Bed (Out 23) ON FOR Frt @ St Bed (Cust Set 7)
THEN DISPLAY "Frt at St Bed" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 26WHENEVER Frt @ St Bed (Out 23) STATE IS TURNED OFF
THEN TURN Bubbler (Out 24) ON FOR Bubblers (Cust Set 8)
THEN DISPLAY "Bubblers" IN Main House (Area 1) INDEFINITELY, [*] CLEARS
27WHENEVER Bubbler (Out 24) STATE IS TURNED OFF
THEN TURN Lt Side Beds (Out 25) ON FOR L Side Beds (Cust Set 9)
THEN DISPLAY "Frt Lt Bed" IN Main House (Area 1) INDEFINITELY, [*] CLEARS
28WHENEVER Lt Side Beds (Out 25) STATE IS TURNED OFF
THEN TURN Rt Side Beds (Out 26) ON FOR R Side Beds (Cust Set 10)
THEN DISPLAY "Frt Rt Bed" IN Main House (Area 1) INDEFINITELY, [*] CLEARS
29WHENEVER Rt Side Beds (Out 26) STATE IS TURNED OFF
THEN TURN Frt of Hs MPR (Out 27) ON FOR Ft o Hse MPR (Cust Set 11)
THEN DISPLAY "Rt of Frt Dr MPR" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 30WHENEVER Frt of Hs MPR (Out 27) STATE IS TURNED OFF
THEN TURN Bet Garage Beds (Out 28) ON FOR Btwn Gar Bed (Cust Set 12)
THEN DISPLAY "Btw Gar MPR" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 31WHENEVER Bet Garage Beds (Out 28) STATE IS TURNED OFF
THEN TURN Rt of Dr Rot Far (Out 29) ON FOR R o Dr Rot N (Cust Set 13)
THEN DISPLAY "Rt of Dr Rot Ner" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 32WHENEVER Rt of Dr Rot Far (Out 29) STATE IS TURNED OFF
THEN TURN Rt of Dr Rot Ner (Out 30) ON FOR R o Dr Rot F (Cust Set 14)
THEN DISPLAY "Rt of Dr Rot Far" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 33WHENEVER Rt of Dr Rot Ner (Out 30) STATE IS TURNED OFF
THEN TURN Rt Prop Ln Rotor (Out 31) ON FOR R Prop Ln Ro (Cust Set 15)
THEN DISPLAY "Rt Prop Ln Rot" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 34WHENEVER Rt Prop Ln Rotor (Out 31) STATE IS TURNED OFF
THEN TURN Rt Sml Gar MPR (Out 32) ON FOR Sml Gar MPR (Cust Set 16)
THEN DISPLAY "Rt Sml Gar MPR" IN Main House (Area 1) INDEFINITELY, [*] CLEARS 35WHENEVER Rt Sml Gar MPR (Out 32) STATE IS TURNED OFF
THEN DISPLAY "" IN Main House (Area 1) INDEFINITELY
THEN SET sprinkler (Counter 2) TO 0
36WHENEVER Sprinkler Off (Task 3) IS ACTIVATED
37WHENEVER THE TIME IS 6:00 AM
AND THE DAY(S) OF THE WEEK IS/ARE -M-W-F-
AND don't sprink (Counter 5) IS EQUAL TO 0
THEN ACTIVATE Sprinkle Yard (Task 1)
