Looking for some ideas regarding the LSA40. I have a Nuvo Essentia and in one zone (sun room) I have a TV that I would like to redirect it's audio to the Nuvo's speakers when we are using the television. I believe the LSA40 is the right way to go here but am a little perplexed regarding where I should install it. From what I can tell the speaker wire (which today runs from the ceiling looped through wall box where the Nuvo control pad for that room is located and on to the Essentia in another part of the house) needs to been connected to the LSA40 and then on to the Essentia head unit. Also, a 12v trigger needs to be run from the LSA40 to the Nuvo keypad. Obviously the TV line-level audio and power need to also run to the LSA40. I could either install the LSA40 behind the TV (and then would need to find a way to get the speaker wire there + the 12v trigger from that location to the keypad) or install it next to the keypad in a double-gang wall box (and just get the TV audio to that location, plus some power).
Questions are: (1) are there limitations to the length of the 12v trigger? If I put the LSA40 behind the TV, that's likely to be something on the order of 30ft. (2) Is the LSA40 the best solution for this application? The audio out from the TV isn't amplified. Should I just try to run a line-level cable from the TV to the Essentia itself and make the TV a source for the Essentia? That run would be approx. 50ft.
