You are correct. I didn't see the correct jumper. I do now. ThanksRAL said:I think you are referring to the data bus connector terminals. That's not where the terminating jumper goes.
The terminating jumper is labeled "JP1" on the wireless transceiver. That's where you install the jumper, if it is the last device on the data bus chain.
If you have one keypad and one wireless transceiver, one way to connect things would be to run a cable from each one back to the M1G. There, you would have the 2 cables connected to the data bus terminal strip. Then, install a terminating jumper on the keypad and the wireless transceiver.
If you add a second wireless transceiver, then you can connect a databus cable from the first first wireless transceiver to the second one to make a daisy chain. Move the terminating jumper from the original transceiver to the new one.
Another way to do things would be to add a M1DBH data bus hub, and connect home run cables from the keypad and each transceiver to the hub. Then, the terminating jumpers get installed on the M1G JP3, and the M1DBH.
Although you can have both a GE transceiver and an Elk transceiver on one system, this isn't normally a recommended configuration. It's easy to run into trouble getting the configuration right. I'd think through your reason for having both types. If you need a GE transceiver because you want a certain sensor that Elk doesn't offer, why not go with GE right from the start?
I needed more sensors so I thought the 2 way communication of the Elk sensors would be better. I bought 2 elk door sensors and a motion sensorRAL said:The GE receiver and Elk transceiver can both work together. Configuration is a bit tricky, since you have to carefully follow the rules for setting up the addresses for both.
If you already have GE wireless sensors, what's your motivation for adding the Elk wireless as well?
RogueOne said:I needed more sensors so I thought the 2 way communication of the Elk sensors would be better. I bought 2 elk door sensors and a motion sensor
RogueOne said:Will the ge transceiver hookup the same as the Elk transceiver and keypad or does the ge transceiver tie into the Elk?
Sorry I meant does it tie into the Elk transceiver like having two smokes connected but you answered my question.RAL said:
The two way communication of the Elk wireless system is a nice feature, but if you already have a number of GE sensors, I would probably stick with GE, rather than mix them. The GE system has been around for years and has proved reliable.
I'm not sure what you are asking. The GE receiver connects to the Elk data bus, exactly the same way as a keypad and the Elk wireless transceiver connect.
No.RogueOne said:When connecting the GEtransmitter to the databus, do I jump that as well for EOL like I did with the keypad and elk tranciever? So a total of 3 EOL jumpers?
RogueOne said:My lack of knowledge is obvious as I didn't understand that. Can you dumb it down for me? Can I do this without having to purchase more hardware?
So if I understand you and the manual correctly I would connect the ge and elk transceivers together with a jumper on the last of the two (much like connecting the two smoke detectors) then the keypad on a separate cable to the data bus with jumper?RAL said:
Take a look at the diagram at the bottom of page 7 of the Elk M1 Gold Installation Manual. It shows how to wire multiple devices to the data bus. Note that there is a jumper installed only on the last device in each of the two chains/legs. The order of devices in the chain isn't important. What is important is that only the last device on each leg gets a terminator jumper, and that there are no more than 2 legs.
If there was only one leg, then you would install a jumper on the last device on the one leg, and the second jumper gets installed on JP3 on the M1G panel.
RogueOne said:So if I understand you and the manual correctly I would connect the ge and elk transceivers together with a jumper on the last of the two (much like connecting the two smoke detectors) then the keypad on a separate cable to the data bus with jumper?
I will give it a try. ThanksRAL said:
Yes, that would be one way that would work.
