Hi Guys,
Got a head scratcher!!
Have just bought a 8ch contactor for switching pool lights, pool water features etc http://www.bellson.com.au/fm/fm1.htm it from a local Australian company. They recently moded the FM only remote control to allow for hardwire control of each channel. Thought you beauty the M1 will control this bonza (Aussie for good!!
Here is the rub! When I got the unit and checked it out and started connecting to the terminal to switch the channels the switching logic is for every contact closure it toggles between the on state and the off state. It doesn't have the ability to be configured for a relay on = ON and relay off = OFF. Momentary for on and momentary for off. The situation is if the unit gets out of sync then there in no way of correcting for it.
What the unit has got is a complimentary +5V tally for each channel, that is when you select a channel on a separate connector on the terminal strip there is a +5V tally open collector output. When the contactor channel is switched off it is pulled down to around .5V or close to ground.
What would be nice is to find a device that would take the M1 relay on all the time instuction and reading the +5V tally know you are switching that channel on.
Conversely it would be nice then to take the M1 relay off all the time instuction and reading the +0.5V tally and know that the contactor channel is off.
I can't think of a simple way to do it with just the M1. Anyone know of a device that might do what I am looking to achieve?
I get back to scrathing my head..... :lol:
Cheers,
Fleetz
Cheers,
Fleetz
