Hi all,
Built the 6 channel master hub, temp/solar and moisture sensors and they were all working fine.
Today I was rewiring the moisture sensor and mistakenly put the 12 volt line into the ground connector of the moisture sensor .
Looks like I have killed the hub, damn.
When I connect the hub to the PC OneWireViewer finds the adapter but will not show any 1-wire devices or channels available.
What I would like to find out is which part or parts need replacing, any ideas?
Cheers - Ted
Cheers - Ted
