Qmavam
Just got the analog meter to work!
Entered values suggested for "Big meter" in Readme.txt into the AnalogConfigurator:
Big meter
Needle length 80
Needle width 3
Max value 67
Min value -17
Max angle 9.0
Min angle 260.0
Origo X 113
Origo Y 103
Then I had to wait a couple of minutes and this was the result:
Yes, its only
in South Sweden right now
Now, the tricky thing to figure out will be how to change the values in AnalogConfigurator in order to correspond to what you want.
I suppose you can make your own kind of image of the meter and then add it to the bitmaps-folder, as long as it is a .bmp image.
/Christer
Big meter
Needle length 80
Needle width 3
Max value 67
Min value -17
Max angle 9.0
Min angle 260.0
Origo X 113
Origo Y 103
Yes, its only
/Christer
