tmbrown97
For the french doors, as said above it's easy enough to protect with two sensors - one for each door, then just connect them in series so that if either one is violated, it'll break the circuit.
For the metal door, what you want to look for is "steel door sensor" - basically they use a bigger hole with some plastic to create a gap between the contact and the metal for better reliability. Here's just a first-hit on a web search:
http://www.homesecuritystore.com/p-204-947-75-ademco-steel-door-contacts-white.aspx
I'm not positive if those wireless sensors you have are compatible with external contacts but there are plenty of others that are - and switching to that style lets you get the transmitter up above the door trim where you'd never even see it really. It sounds like a good solution for the problems you're having.
