BraveSirRobbin
Moderator
I'm in need of a transducer to measure the fuel capacity of a 250 gallon and a 350 gallon LP gas tanks. I need to know the fuel level in these tanks. These tanks run generators during power outages in remote areas.
I was chatting with WayneW and Scrambled this morning and we all kicked around some ideas such as measuring weight, monitoring generator run time to calculate fuel left in the tank, etc... but I'm still wanting a way to show the fuel level in a real time status via a (pressure) transducer (and output this voltage to a data logger).
I have a data logger, solar power system, solar power peripherals (battery, charge controller, etc...), Motorola Canopy subscriber module for communication, data logger, serial to Ethernet converter, etc... for these areas, I'm just missing this one item. I will also be monitoring other aspects of these systems such as generator current, etc...
I was hoping that some members would have experience with this LP gas tank monitor and kindly give me some advice.
HERE is something I was considering, but before I call a vendor, I was hoping I could get some advice here.
Also, I'm assuming that pressure would be the monitor method of choice. As I stated earlier weight measurement isn't a viable option for these areas. If there is another method, please let me know!
BSR
BSR
