I just completely outfitted our new house with over 50 RA2 dimmers. I used 6NA dimmers for about half of the fixtures and they are working great. However I am getting flickering from the LEDs in the 4" HALO cans wired to 6ND dimmers. The fixtures are just the regular ICAT HALO recessed cans and the bulbs are Elite LED bulbs from TCP I believe. They start flickering at around 50% dimmed until they are completely off. We want to be able to dim below that adjusting the the low limit setting isn't a solution for most of them.
I'm going to see if the electrician can work with me in terms of replacing the bulbs, but I am not placing fault on him as he was unable to confirm that the combination would work and I made the call to go with the 6NDs - and purchased them myself. I am pretty sure the bulb is the key ingredient in this setup and the HALO cans shouldn't have any impact the dimming performance. So, I need to find a replacement R30/BR30 bulb that will work with the 6ND dimmers. Price is a bit of an issue as there are probably about 20 lighting circuits using this setup with upwards of 100 bulbs. Anyone know of any LED bulbs that will fit my needs?
Matt
edit: I should add that I did try the Lutron compatibility tool, but the 6ND dimmer doesn't show up on it yet.
Matt
