CVTeammember
I have seen a H.264 8 Channel DVR with 3G capabilities online. It's a network DVR that can play back over a network. You could even sync up a smart phone like an iPhone or a blackberry and stream your video footage through a surveillance DVR. It should have the feature 3G/ GPRS mobile phone monitoring. If you're looking for quality definition, look for something VGA output up to 1024x768 resolution. It should have USB ports for mouse control and backing up the DVR. if it has dual streaming your network speed will be fast. Each channel should have an individual setup of resolution, frame rate and video quality. Some have a still image snapshot to capture pertinent video frames. You will need a time stamp feature. The H.264 compression is ideal for saving HDD space. A multi feature DVR will be able to have a Live display, record, backup, playback and network access simultaneously. Quality DVR's have picture-in-picture monitoring and 2X to 8X digital zoom display. Most controls are on the front panel, but many have a USB mouse control, IR remote controller, and or a client viewer control. (meaning someone with outside password protected authorization can log into the network and control your DVR. If it has the feature (Pan / Tilt / Zoom camera control), pan tilt zoom cameras are compatible with the surveillance DVR. Find one with a menu driven operation. A smart idea would be to get a DVR with a network-Event triggered alarms. If there is motion detection, alarm sounding or video loss the network DVR will notify you via email, if you would like. Get a DVR that supports Internet Explorer with the same GUI as DVR site. I can't tell you the benefits of a multi-language OSD, at least not in French. A CMS (Central Management System) is the software that should come with it. I did a surveillance DVR search and got this video surveillance DVR. (3G H.264 8 Channel DVR-83G) it's an 8 channel and will do all the things i have listed. Hope this helps in some way inform you of what could be out there.
here is the link to the H.264 8 Channel DVR-83G
there is also some information on DVR Surveillance Recorder solutions
