I was wondering if anyone out there has any experience with the ELKM1KAM door access module? I am having trouble triggering the form C relay on this board. The module is set to address 2 so output 194 should be what is turned on and off. Problem is that relay will not trigger. Any suggestions?
I have setup rules using a proxy reader with same module on address 2. The reader works fine and I am able to trigger the form C relay on output 3 but not 194. I believe the relay is in good working order since it clicks when powering on and off the system. Any help would be much appreciated.
