tunafishhkg
Hi,
I have the M1 Gold and have a problem with it not taking the password at the keypad. It has been going off on alarm for the past 6m when entering my code, usually at the last digit but it did not do this all the time maybe 6 times then ok for three. Now it will not take my master code and I have to go in with RP on laptop hardwire at the M1 to reset syst, then can hit code on keypad and leave. If I go back in, it will not take code and I have to start all over again. This new problem started after a power outage and my Gen did not kick in so was out for 30hrs. I believe my back up batt is still dead in the M1 till I do a charge would that cause a prob with keypad code? I installed another keypad with no results. Also I have a spare MXEP that says old firmware and need to know how to flash new firmware or will the M1 send it to it if installed, since that has all the new firmware?
Thank you!!
Thank you!!
