DubG
Hey guys, I did a quick search and couldn't find any posts on using a Micra G with an Elk for this purpose so I thought I would do a quick write up. RF2G is in the garage, 40' from metal mailbox in brick/mortar. It didn't get reception inside the mailbox so I drilled down between the bricks using a masonry bit and broke through the metal mailbox and simply ran the antenna up the hole. It is just barely visible and I'll need to paint it some color other than blue and use silicone or caulk to seal the hole and the end of the antenna but I really like it. I used black duct tape (mail box is black) to secure the sensor and the magnet. Not the cleanest install but you can only see it when the door is open. Now I'll not only know when the mail lady comes but also if anyone decides to go through my mail! Not bad for 30 minutes and $25
My mind is racing with the "rules" possibilities now...
