Can anyone suggest the best way to solder a mini 10 pin BT connector to my Asus 900A netbook? The 10 pin traces are very close together and small. I would have to solder the connector to these traces. I do have one of those lamps with the large circular magnifying glass. I have soldered SF stuff but many many years ago (10 years or so).
I am currently using an external mini-BT model which is OK but would rather utilize an internal almost OEM solution. I purchased a ASUS OEM BT module with a 10-pin connector. The traces are on the motherboard for the other side of the connector. I also have purchased a combo BT/WLAN mini PCIE card but found out that the BT part of the card requires some sort of USB pin voltage change for it to work correctly. My other attempt has been to purchase a mini-USB hub which is small and can be fitted inside of the netbook and connected to the camera USB port.
Here are a couple of pictures of my EEEPC 900a. The first one is an overview of the top of the motherboard and the second one is a close up of where the BT connector traces are located.
Here is a picture of the EEEPc 901 with the same Asus BT module that I purchased.
