More Garden Light Pics
FrankMc said:
Hi Guys
Kits available for the REGBLED Boards......
http://www.rgbled.org/
HTH
Frank
Arrggghh. :eek: Check out that sprinkler controller at that site.
I'm so upset. I JUST finished building my own elaborate circuit with (old school) relays and a hardware (555 timer) watchdog to make sure nothing gets "stuck" and water the same spot for 5 days straight.
Mine utilizes logic lines (I'm using a parallel port until I get the Elk M1), but this is just as easy to interface with.
The micro controller is a much more elegant way to do this.
Looks like I'm going to build a new one. :D
Thanks for the link.
And to stay on topic....nice lights. I just put in a bunch as well. I can't wait until I jump on board with HA so I can control all this stuff.
R,G or B is over the top for me. I took a quick look at the site but didn't find this answer. R+G+B=white. Is that possible? I.E., all 3 on.
TIA
Hi
>R,G or B is over the top for me. I took a quick look at the site but didn't find this >answer. R+G+B=white. Is that possible? I.E., all 3 on.
>TIA
I initially thought RGB LLeds were a bit over the top , but once you seen them in action , they look really nice......
Yes .R+G+B = White...........
Frank
TIA
Yup -- all 3 on == white, but you can pick any shade between black/off and white (like pink, aquamarine, ochre, yellow, red, etc). Standard 8 bits per color resolution meaning there are technically 24 million colors possible, though it's unlikely you'll be able to see much difference in some of the subtler colors.
Gerry
