I got my bench testing as far as I can take it so now it's on to the actual installation.
I got the 28" ELK panel and there is only one set of holes at the top of the panel that fit the M1G assembly's footprint.
I wanted to move it down farther in the panel and also wanted to mount it on some nylon standoffs so I can run wires underneath it.
I just wanted to check whether there is a reason not to do this. I was planning to use the 4 holes in the main circuit board, at the corners and under the black cover, as the mounting holes for the M1G assembly in the 28" panel. I was going to use four 1" nylon standoffs underneath the M1G assembly, and 4 nylon screws fed in from the backside of the panel, through the standoffs, through the M1G assembly, then a nut on the top.
Is this OK to do? I wouldn't be electrically connecting the M1G to the panel since I'm using nylon screws and standoffs, but it doesn't seem like these mounting holes in the M1G are connected to the board's ground anyway.
