lleo, on 05 Sept 2014 - 18:29, said:
I also went down the road you are charting here...
Surely, ground source heat-pumps, AKA geothermal systems are the most efficient. But they are pricey. Where I live on a rocky hill, the quote to replace my two old airsource heatpumps was $65K (5 wells drilled in hard rock and related systems). And I have a large, but single story home, with full basement and all duct work run in conditioned space, very accessible, and plenty of space to spare.
Word of advice: don't fall for marketing numbers, and make sure you understand the differences and difficulties of converting between SEER / EER / COP and the remainder of the alphabet soup. Most of these numbers are derived in controlled conditions with a like a 2' worth of duct work.
For example my Carrier Infinity air-source heat-pump has a COP of 3.9, i.e. for every 1000W used it is putting out 3,900W worth of heat. But even at this efficiency it pales to natural gas, where to produce 1M BTU with the heat-pump cost almost twice more versus burning natural gas to get 1M BTU.
In the end this help not a iota the enviroment and while might be saving some energy(money) for you, as you may be efficient but electricity is still generated by burning non-renewable fuel.
So I concluded that unless I had a sufficiently large solar system to produce free electricity and even store the excess for dark hours, my money is better spent to improve insulation and tightness in my home. I still replaced my old HVAC systems with a zoned system and even paid extra to have a heat-pump, just in case I get access to real renewable energy one day.
Another topic: The number of zones and range of operating capacity are less important. The zones were invented to keep an HVAC system in the 'sweet zone' i.e. where they are the most efficient, and this is NOT 0-100%. For most, this is in the 50-60% range. Your pursuit of a 0-100 percent range will have to trade efficiency.
There are requirements, such as when you want to keep the temperature variation within 0.1 and 0.5 degrees, where you will need a 0-100% modulating control, but in this case you are not concerned of efficiency, all you care is to keep the temp.
As I alluded in my earlier post, as long as the temperature is below about 90, I end up using less energy over a day keeping my home at 75, which means that my system hums along at 40% capacity during the day, with few spikes in the afternoon, versus doing a setback of 80 or even 85 during the day (i.e. 9AM-5PM) and do a recovery from 2-5PM (during which the AC runs at 100%) to reach 75 at 5PM. Your house where it is may be different. We had a very nice summer and I have not used more than 1200 KW/month (4BR+pool) with my 'gadget' budget in standby is 300W 24/7/365. While I think in my research circles this energy use is low, and is perhaps nothing remarkable compared to other (please do not take this comment as flaimbait to start who uses less...) I also know people in other parts of the world, where their monthly electric energy budget is 100-150KW.
So yes, energy efficiency is good, but always consider the cost and gain.
I think you mentioned, but Carrier Infinity can handle 8 zones on a single system, and the network interface with serial and IP access I have can handle 4 systems, each with 8 zones, and up to 4 remote temperature sensors averaged per zone. That translates to 32 zones with 128 temperature sensors. I cannot imagine such a house. One more thing, in new construction, one can do complete heat and energy recovery and recirculation, where your fridge, cooking and A/C may be heating your hot water, and in cooler months you could tap in your hot water for your minimal heating need a super-tight house may need. Edit: forgot to add the energy recovery in the sewer line, so that while you shower you also heat water or your home...
