beelzerob
Well, since I now have the Brultech ECM-1220 up and running and I'm now reading data into my CQC driver, I figured I'd post a few pics of what I've got. It's not much, but hey.
Here's the package contents.
I have the package where the plugs are on the outside (top) of the monitor. So, on the top there are 4 plugs....2 for the CT's, 1 for the transformer, and 1 for the USB cable.
Here is the pic of the CT's after they were installed by someone much braver than me.
The installation document says to make sure they're installed on a straight section of wire, and I noticed that he put it kinda on the bend. Paul, if you're skulking around...will that matter enough to fix it?
So far, I'm quite pleased with the whole package. The display responds VERY fast to changes in power....essentially instantaneous. I grabbed my power drill laying nearby and watched the current display while I revved it a few times. The amps changed accordingly.
I installed and fired up the free Lite software, and I just looked at it long enough to see that it was sending data, but I'll be honest, I've not done a very detailed inspection of what this unit is capable of. That's because I'm solely focused on getting it to work fully in CQC first. Then I can play around with it. However, my panel is planned to remain in the basement near the power panel, so CQC will be my primary interface to the data provided.
