Guy Lavoie said:
			...or just a single cable coming from the light fixture with the hot and the switchleg going back to the load ie: the light fixture. This second scenario is the one that you can't use with Insteon, UPB, etc...
 However....
Isn't it true that you can actually "re-wire" this into a workable solution?
The issue is that the LINE (along with the neutral) is either (1) at the fixture or (2) another switch location...isn't it?
It was my understanding that you can disassemble the circuit...I am definitely NOT knowledgeable about this...
If it is a 3-way, can you isolate the "secondary" switch location by rewiring it into a LINE + Neutral + Ground that is not controlling any load? Then rewire the rest of the circuit into a single switch controlling the load. You may have to go into all switch locations and the fixture box to do it. When you drop in your Insteon switches, just link the "isolated" line-only switch back to the actual load switch controlling the fixture....
If the switch is the ONLY switch, then once relay modules are available, won't you be able to do the same: Wire a relay into the fixture, convert the switch to a LINE/Neutral/Ground, and control it that way?
Just wondering...because it took me a while to understand that the first step in Insteon wiring is to disassemble existing 3-way wiring circuits.
When I first started peeking into my switch locations, I was initially concerned. Then I figured out that there is only one location that is an issue at my house--a 3-way hallway light (which I plan to handle as described above).
All my other potentially difficult boxes are multi-switch locations, and so there is definitely a neutral available.
