jrfuda
BSR - but think of al lthe fun we'd of missed out on
Anyway, I want to keep all of my sensors on my SECU16 on the same logic - all with open meaning one thing and closed another. So far the only things I have as sensors on my SECU16 are currrent sensors, and these are NC by what was said here. their circuits are open until they detect sufficient current and then their circuits close. So for my setup, open means off and closed means on (and that's how they appear in CMAX). What's funny, though, is to get this to be read by HS without too much scripting, I had to reverse the inputs (or something like that) in the ADIOcelot plugin (prior to that, HS saw a CMAX on as an off and vice versa). So, given that, given that I use DooMotion, and given that DooMotion see's "on" as motion by default, if I want the door opening to be regarded as motion and it closing regarded as the end to motion (the same way you'd use DM to monitor a regular door 'cept you change the custom status from motion/no motion to open/closed), that means I'd have to have an open door=on in CMAX, which means an open door = a closed circuit, which means I was wrong all along and need a NC swith, so the end result is:
Door open = circuit closed = CMAX on = HS on = DM motion
Door closed = circuit open = CMAX off = HS off =DM no motion
Does this make sense to y'all?
I'll get a sensor at Ratshack (forgive me Martin) this week and see how it works, if it's not what I expect I can return it rather easily. I'll let y'all know how it goes.
