grimreaper1014
Hello,
I have a lot of stuff around my house causing EMI. I have ordered CAT5E STP to redo the wiring in my house. I have never used STP before. My router came with a CAT5e STP patch cable. I have also noticed around the ports on the back of the router there is metal outlining them. There are also little metal tabs that extend from the outlining metal down into each port on both sides. I would assume this is for using STP? Will my router provide the ground? I would think this would be the case since it came with a STP cable right?
The way I was planning on wiring up the house was to use a piece of CAT5e STP from the (NID) telephone box where it will be grounded to a RJ11 keystone jack. Then, I would connect a telephone cable from the RJ11 jack to the DSL port on my modem. From the WAN port on the modem I will be using a 35ft CAT5e STP cable to my router. From the router I will have another CAT5e STP 35ft cable to my Xbox 360. Finally, I will have a CAT5e STP 7ft cable from the router to my desktop. Is this setup going to work? If not what do I have to do so these cables will be properly grounded?
Thank you,
Rocky
Thank you,
Rocky
