Hi. For a second time in a row the rule which is based on sunrise/sunset did not get activated. I have no idea what is going on simply because i tested the rule by changing M1 time from the PC and simulating sunrise and sunset times.
First of all, correct me if i am wrong here. Due to Daylight Saving Time the sunset time should be padded by 1 hour, which means if sunset is at 6:20pm then the rule will actually get triggered at 7:20pm. Yes / No?
Well here is what i have now:
- I need to turn the output 8 on one hour after the sunset:
When time is sunset + 2:00 hours then turn output 8 on
and
- I need to turn the output 8 off at sunrise:
When time is sunrise + 1 hour then turn output 8 off
For some reason this is failing. I do not know of a good way to troubleshoot other then call my cellphone when this rule is triggered, but the phone did not ring so i guess the rule never got triggered.
I guess what i want now is this:
check every 15 min.
if the time is one hour past sunset then turn output 8 on
also
check every 15 min
if the time is equal to sunset then turn output 8 off
this rule seems to be more reliable, but i read somewhere[i think it was the elk newsletter] that the sunset values are only valid till midnight and noon.
anyhelp on troubleshooting and rules is appreciated.
thanks
and
check every 15 min.
also
check every 15 min
thanks
