forgets
so I just got in a new m1xsp to integrate with my rcs zoned hvac system, but something's not working along the way, so I'm looking for help.. first off, I can connect the rcs to a pc via serial and poll it with A=1 R=1 and it'll respond back (I even used the cable that comes with the m1xsp to rule out the cable).. everything was set up as per the instructions in the m1xsp manual for rcs serial, mode set as 1,0,0,1 set to rs232 , and address 2 (tried address 1 as well) I enrolled it into the elk, and updated the firmware to 1.0.3x? (I forget the exact version, but its the latest... I set up the 4 rules and tried them out... however when trying to view the thermostats from the keypad it says t1 (thermostat1) 'not enabled' ... also when trying to view them from the m1xep it unit not communicating' from the climate tab.... the light on the actual m1xep alternates between a short blip and a long blip of light... which I think is normal...? (figure its communicating with the rcs maybe?) ... finally I tried hooking it up as a serial expander mode 1,0,0,0 baud 9600, and tried a rule to send text out the port, but received nothing from the port of my computer which I'd hooked it up to.... I'm stuck, is my brand new m1xep a dud even though it enroll's just fine ? did I miss something ? I tried searching for solutions, it seems sendero had the same problem but no solution was ever posted in his thread... any help is greatly appreciated.
thanks.
thanks.
