johnnynine
In this case I'm trying to figure out if an IR repeater distribution block would work for me.
I have my home theater components in a media cabinet with glass doors. I also have several sources of video: directv, old tivo, playstation, dvd player - all of which currently plug into a separate input on an lcd hdtv (hdmi, svideo, hdmi, component; respectively).
I use a Harmony 880 remote control which used to work well with a quicker crt tv and all the video sources switched through a receiver and connected to the tv via svideo (the exception was dvd which was connected via component). In any case this setup was fairly easy to use since the video source rarely needed to be changed and the tv didn't take 7 seconds after turning on before it would respond to ir signals.
My wife hates our new hdtv setup with the harmony remote since we commonly switch between hdtv and tivo (which are connected to 2 separate tv inputs). Since the TV takes 7 seconds before it can receive ir signals, my wife usually sets the remote control down before everything has been set appropriately. To make things work the Directv ir receiver is terrible... you have to point the remote directly at it for it to work (not sure if it's the glass or just he unit). Then we also have audio to the tv and to a receiver.
You can see where this is going... When my wife tries to watch tv, things are almost always out of whack... direct tv on the screen with tivo audio and the combinations go on. I'm fairly technical and remember to keep the remote pointed in just the right locations at the right times so I don't have as many issues, but I need it to work for everyone.
1. I think there are several things that would help... If I had all the audio and video plugged into an hdmi capable receiver that would help a lot with things getting out of sync. Unfortunately it looks like a decent hdmi 1.3 switching receiver costs $600+. Any suggestions?
2. Then there is the issue with the directv weak ir receiver. Tivo is also behind the glass and responds quite well, but the directv box is very touchy... you have to really be pointing the remote almost right at it. I'm wondering if an ir receiver that plugged into a an ir block would help. If I did this would I need to completely block the component's ir receiver from the remote's ir signal?-- ie, would it receive overlapping ir signals, one from the remote and one from the repeater?
Johnny
Johnny
