New board suggestion
Platypus
Hi Eric,
I don't know if you take suggestions for new products but I would like to propose one, or at least a modification to an existing one..
I think I'm right in saying your current moisture meter board will only handle one moisture sensor so that another meter is required for each additional sensor.
I would like to be able to have one moisture meter with a built in DS2408 to enable me to connect up to eight leaf or gypsum sensors and switch between them. This would greatly simplify the 1-wire network and reduce the part count significantly.
Thanks, in advance, for considering this.
Regards
Neil
ericvic
Neil,
That sounds like a neat idea. I will put it on the list for future devices.
Thanks for the suggestion.
Eric
