Looks like the folks at Elk Products have been busy. They released several new firmware updates for the M1XSP and M1XEP. Straight from our residential Elk engineer:
Elk-M1XSP Serial Expander Firmware (various versions) released 10/29/08
Seven updates are available for the M1XSP:
1) The standard version - M1XSP_Update.exe (1.0.42)
2) A version dedicated to Insteon Lighting - M1XSP_Insteon_Update.exe (50.0.28)
3) A version dedicated to Uplink and AES radios - M1XSP_Uplink_AES_Update.exe (10.0.2)
4) A version dedicated to the JetStream Lighting Interface - M1XSP_JetStream_Update.exe (30.0.8)
5) A version dedicated to the OmniStat Series 1 & 2 Thermostats - M1XSP_OmniStat_Update.exe (70.0.2)
6) A version dedicated to the ViziaRF (RZC0P) Lighting Interface - M1XSP_ViziaRF_Update.exe (20.0.4)
7) A version dedicated to the M1XZW Elk Z-Wave Lighting Interface - M1XSP_(M1XZW)_Update.exe (1.0.16)
Elk-M1XEP Ethernet Expander Firmware 1.2.14 released 10/29/08
Release Notes:
1. Added support for the AMX Duet Device Discovery routine. ElkRP now provides a new option under the M1XEP
Setup button. The AMX option must be checked in order for the AMX Beacon message to be broadcasted.
2. Implemented support for a new special ASCII “AP” command that an M1 can use to send data to software applications.
Refer to the Elk ASCII Protocol documentation for more details.
3. Found and resolved an issue that could cause the Java Webserver application to lock up if the login code happened
to be the Installer or RP codes. Basically, the Java app. now checks for a return reply of whether the code is user/
master/installer/RP. If not user or master, it displays “Invalid Code.” but should no longer lock up.
4. Found and resolved an issue with the Java webserver application that caused the display of Outputs to be sized too
small to view on MacOS systems.
5. Found and resolved an issue with the TEST button in ElkRP for testing DynDNS and NTP servers. The XEP wouild
sometimes report back to ElkRP that the test passed even when it didn’t.
Release Notes:
