apostolakisl
As far as the well.
I suggest getting a CAI webcontrol board. You can run a cat6 wire out to the pump house if it isn't too far which would be used to carry IP traffic. The CAI board is controlled via IP. You can put relay boards onto the CAI and then control and view the status of it over the internet. You could also get a wifi adapter for it and avoid running any communication wires out there at all. http://www.amazon.com/NETGEAR-WNCE2001-Universal-Internet-Adapter/dp/B007CO5DZ4/ref=sr_1_1?ie=UTF8&qid=1363887861&sr=8-1&keywords=wifi+netgear+bridge This will also get rid of the risk of a lightening strike conducting up your cat6 and frying a bunch of stuff. Also, it will be cheaper than running shielded cat6. Still, I would run a conduit out there that you leave empty just in case you want wire in the future. You will obviously have a trench already since you need power and the water lines back to the house. Make sure the electricians give you 120v and 240v out the pump house.
The cai board can control up to 8 relays which can power your valves. It also can handle 8 temp sensors (though I see little call for more than 1) If you want to get fancy with it you could have it monitor well head pressure, wind speed, rain fall, and other random things.
