Tessa
I think I was with you for most of your comment.DELInstallations said:[...] the 485 bus [...] OAL [...]
, but again, the limiting factors are going to be the OS and the mobile platforms until they really proliferate the other side of the coin. You're going to need to take it a building at a time and really get them talking and the components in place first. My first leaning would be to get into a system that can interface and speak BACnet.
But, to my sorrow, I think you may have started putting words from foreign languages into your otherwise-intelligible comment
~DELInstallations said:You're really starting to get into the commercial controls realm with your want list
Can you please clarify for me why you say so?
* Is it the diverse nature of the controls that we want?
* Is it any particular control set (like the door operators)?
* Is it the total number of controls that we want?
* Is it the multiple outbuildings by themselves?
FWIW, we have an overhead view of the property with surveyed measurements along the property lines. Judging from those, we have layouts of the lines we're going to be trenching and where we think we need to put all the outside wiring and plumbing. We shouldn't need to run more total footage than about 1200 ft (and that's to get power/water to every part of the property; hopefully there will be a bit less in actual networking). The longest individual run (and this one has everything: power, water, cat6, everything) should be just under 300'.DELInstallations said:You can only run 4000' total end to end [...]
The wiring is going to be the largest item...it needs to be installed and certified while the building is happening.
Our electrician (handling power inside and outside) is also comfortable and experienced with pulling cat6 (and coax, if we wanted it) and putting in cat6 jacks. He's willing to run cat6 out to all the outbuildings for us.
I noticed that quite a lot of the junctions[* I may be misusing this word, my apologies] where we need wiring for automation will also be power junctions, like the wall switches for fans and lights. When I asked him, the electrician said he'd be happy to give me an additional estimate for pulling wires for automation from the control cabinet to the various power junctions. (and labeling them thoroughly) He'll even do it in the outbuildings; I just have to determine where I want the "control cabinet" in the outbuilding, and where I want the wires.
However, he can't hook it up (at either end) once he pulls it. And he can not advise me on what specific wiring needs to go where. He asked me to give him a wiring diagram (he said my looooong webpage outline might be good enough, he'd take a longer look at it). He needs *ME* to specify which type of wires go where.
I don't actually know what requires cat6, what requires 4-strand "alarm system wire," what requires 2-strand "alarm system wire." My rough understanding, so far, was:
* Anything that's just a sensor requires 2-strand.
* Anything that needs to act as a sensor as well as send simple toggle signals (like on/off controls) needs 4-strand.
* Anything more complicated than that needs cat6.
When I asked the guy giving me quotes for window/sliding glass door operation what kind of wiring it would require to additionally hook the operator into an automation system, he consulted with his consultant, and came back and said, "We need to know what kind of automation control system you're putting in first."
Erp. I thought I could get all the wires in place THEN hook them into a system. Eventually. Possibly installing the actual automation hardware over the course of years, as new hardware becomes available, other hardware gets less expensive, some elements become more urgent as my condition deteriorates, etc. [The window/door operator estimate guy *is* aware of this, incidentally, that this is a long term project, with possibly nothing done immediately.]
They can't just TELL me if it needs cat6 or it needs 4-strand or what? Or if it needs one of everything? Or multiple 4-strand, one each for motion sensors/manual buttons/any other sensors, plus one to activate/deactivate the operator?
Aw drat.
