ccmichaelson
Equipment Already Purchased
- (1) Elk M1 Gold Panel
- (1) M1XEP - Ethernet Interface
- (1) ELK-M1DBH - Data bus hub
- (4): ELK-M1KP2 - keypads
- (4): ELK-SP12F (flush mount speaker)
- (1): 14" enclosure (came with the kit)
- (1): 28" enclosure
- (5): Garage door contacts (3 attached to house, 2 in detached garage - planning to purchase a contact that I can attach at the header/top where I ran the wire too)
- (9): Exterior door contacts (Tane brand)
- (16): Exterior window contacts (Tane pill)
- (42): Motion sensors (Bosch BlueLine Gen 2)
- (1): Doorbell - TBD
- (9): 4-wire smokes (2 of them will be smoke + CO)
- I know the panel only supports a limited number of powered devices so what do I need to purchase to power the rest of my sensors?
- Given the number of devices, what equipment should I put in the 14" enclosure and what should be in the 28" enclosure - or will the 28" be sufficient?
- I'm planning to daisy chain the 4-wire smokes (based on prior feedback), so if the first smoke is connected to the power supply (on the main panel or secondary power supply) can it power the other 8 smokes?
- Any other tips/comments welcome!
