snakevargas
I've installed one of these with an Elk M1G, and I'm trying to figure out how exactly to test it. I have a FG-701 simulator.
How does 'test mode' differ from normal mode with the NX-487? If I generate an event with the FG-701 (by putting the switches to flex/test and then smacking the window) while the NX-487 is in normal mode, then should it send an alarm signal to the panel? I kinda tried that, and it kinda seemed to not do anything.
Putting it in test mode, I seemed to be able to cause an event to be sent to the panel. But, I'm not sure why it only seems to be working in test mode. The FG-701 simulates a glass window breaking, right? Shouldn't the FG-701 set off the sensor regardless of which mode it's in?
