NX-650 Codes?
There is a "Transmitter Low battery" on the keypads also.
Thanks for the quick response
If I pull the battery on a NX-650 should I see that message?
John
If you pull the battery you will see a lost transmitter message when the panel does not hear from the transmitter for a few check ins. If you put a discharged battery (probably 2.4 V or so) in the transmitter you would get the low battery during the next regular status check in. Status is sent around every hour or so (at least 61 minutes).
