I am swapping an Elk M1G in for an old panel, and the old system includes a 2 wire heat sensor, mounted right over the furnace. It is a Fire Systems Model 604, and the two wires went on from that to go to the power input of a series of 4 wires smokes elsewhere in the house. Googling, 604 is long since discontinued, but I did find some pdfs on line for a seemingly identical model, Chemtronics-600-Heat-Detector (cocoontech.com won't let me paste in a lnk as I'm new to this site)
Certainly I can take the 4 wires smokes and wire them up as I like to other zones, leaving me with this 2 wires sensor as a standalone problem to deal with. What is the best way to deal with it:
1. Toss it, and replace it with a conventional smoke detector. The old furnace used to be oil, but the new one is high efficiency/propane, so I don' t think falsing would be a problem? Or is there something desirable about a heat sensor instead of smoke for use over a furnace, and I should find some modern 4 wire heat sensor?
2. Keep it, and wire it up to zone 16 with an 820 ohm resistor as described in the Elk manual. If so, two questions... the manual page 6 mentions various compatible models, and does not mention mine. Is that a problem, is 604 not compatible if not listed? Also, how critical is the value of the 820 ohm resistor... can a 1K be used instead?
Thanks for your help!
