lupinglade
Just installed two new OmniStats and the humidity readings seem to be high by about 10%, compared to multiple other readings including readings in the same area by an HAI Extended Temp/Humidity sensor. The hole in the wall is well sealed w/ spray foam. I know for a fact the reading is 35-40% RH but the OmniStats say 50%. I have an older OmniStat that also had this issue initially but seems to have become accurate after the wall hole was sealed w/ spray foam about a year ago. Is this because the thermostats are new and the humidity sensor needs to dry out or some kind of a bug? The new thermostats have been installed about 48hrs ago.
