I just tried to install an Omnistat RC-1000. When I power up the system, the screen flashes on and off for repeatedly (about 2sec intervals). None of the buttons do anything. It appears that the temperature is accurate as it changes between 69 and 70 degrees.
I have a single stage conventional furnace as far as I can tell. It has a fan and heat, no cooling.
The current wiring to a Honeywell programmable thermostate works fine. There is a red, white, and blue (which is actually wired to the "G" terminal in the furnace and on the Honeywell). I checked on the furnace side and White is run to W1 and W2, Red is run to R, and the Blue wire is run to G. There is no common wire run.
So, i put the red (hot) in in slot 1 and left the jumper to slot 2. I put the White (heat) into slot 6, and put the blue/green (fan) into slot 8.
Do I need to run a common wire? What color would that be on the furnace side? I'm guessing its the screw marked "BK" (Black), right next to the Red, but I want to make sure I don't screw things up.
Or, is there insufficient power do you think? If so, what do i need to do? I read another post that suggested there isnt sufficient power and I need another power supply.
Clearly, this is my first time doing this
, so thanks for the help in advance.
Chris
Chris
