Hi,
I bought a omnistat2 (RC-1000) and an extended range outdoor temperature sensor. I wired everything like the installation manuel said.
My outdoor temperature sensor is wired to zone 10 and I have set zone 10 to extended outdoor temp. Everything is fine with this. I can see the temperature sensor in PC Access no problem.
The problem is I don't see the thermostat in PC Access. I verified the wiring continuity between the omnistat2 and omni IIe and everything is ok. It is wired to zone 16 and output 8, as the manual said. I also rename the zone 16 to "Tstat" in PC Access but no thermostat appeared after. Communication is set to serial and I tried address 1 and 2.
Is there any other configuration I need to do so I can see the omnistat2 in PC Access ?
Omnistat2: RC-1000, version 1.05b-zha, V14.27
Omni IIe: firmware 3.7
Thanks in advance!
Thanks in advance!
