felixrosbergen
Hi All,
I'm set on using ALC for the lighting on my house, but am on the fence on how to control it.
I will have CQC and Elk anyway so either one woudl work for me.
Since the ALC switches work even without a controller I'm not so concerned with the stability of the control system.
Beelzerob seems to have a good working driver for CQC now.
Has anybody controlled ALC with an ELK? How does that work? How does the feature set compare to the CQC driver?
In the end i will want the lighting to respond to sensors and other inputs which are mostly contained in the ELK.
ALC makes a special interface module to interface with the ELK, but it's also possible to use their normal controller with serial board and then use the elk serial expander. If i go that way i guess i can be the guinea pig if nobody else had yet.
Of the WAF will suffer...hahaha
