That will work but introduces yet another point of failure. What we have done in all our facilities is run all the data (like your hub/switch/phone, etc) into 1 set of panels then wire all your endpoints (like the jacks) into another set of panels. The panels have 110 blocks on the back and RJ45's on the front. You can get swing brackets for the wall or put them in a rack. Add some Panduit for cable management an you are in business. To use you simply use an RJ45 patch cord to patch from source to destination. You never need to mess with the blocks on the back unless you are adding new sources or end points. Clean, simple, flexible and very easy to maintain. You can put is all in 1 panel or even better to use separate panels for each of your sources - like 1 panel for LAN, 1 for phone, etc. and you can separate panels for destinations like first floor/second, etc.
