Well, it's coming together nicely so far. We got the area cleared and leveled, and now we can visualize the structure much better. I think we're going to end up with a "pavilion" basically, instead of a pole barn. That's because I'm leaning towards using built roof trusses. So that means I'll just need to put in the posts and beams.
For those with any knowledge in this, I have 2 questions:
1) Of course the posts will be pressure treated...do the beams have to be also? They should be sheltered enough by the roof so that decay isn't an issue. I know the roof trusses won't be pressure treated...so just checking about the beams.
2) I have some spare 1" underground conduit, so I had planned to bury a line going from my house to this pavilion so I can put in lights, and should the need arise, also run some cat5 maybe for a little weather station on it. For power for the lights, I was just going to run a line from my nearest GFCI outdoor outlet on the house. Is that a bad idea? I'm not going to be putting outlets in this thing, this is only for lights. I'm pretty sure I don't need a subpanel for this, but I didn't know if grounding was another issue. So basically, is it ok to power lights in this external pavilion (about 50 ft from the house) from a house outlet?
Thanks for the helps.
