jmed999
I have a rule set up to change output 65 to "on" when my cleaning lady disarms the Elk M1G. Another rule changes it to "off" when she arms the system as she leaves. The output changes trigger text messages to me and it changes the thermostat so that she will be comfortable while she is here then change it to an economy setting when she leaves.
The problem is now the output will change to "on" properly but doesn't turn "off" when it should. It was working perfectly so I'm not sure what is going on.
The rules are...
Whenever Home Arm state becomes disarmed
and last user was user 3
then turn output 65 to on
Whenever Home Arm state becomes armed
then turn output 65 to off
What could the problem be? Thanks! (Edit: I had the disarm and arm in the whenever part backwards)
The rules are...
