Panasonic SW174 Wireless IP Camera
michael(fl)
has anybody used this camera in the wireless mode?  i have it setup correctly on wired, works great.  but when  switch to wireless with the wi-fi protected setup (WPS) i can't find the camera on the network.  the router and camera both return successful WSP setup.  when i switch back to wired it works great again.
thanks in advance-
No experience with this particular camera, but I'm wondering if you can do the wireless setup with the hardwired connection (i.e., IP address, security key, etc) and then switch over to wireless.  If you can avoid WPS, you will have more control over the settings and, perhaps, avoid the problem.
hi jpmargis,
thanks for the reply.  I tried that on the first couple of attempts, then used the WPS because it was 'easier'.  Over the weekend I did a hard reset and did the setup the old fashion way and it now works.  Thanks -
