Question probably for Work2Play, what about the Venstar T5800 which has drivers for both RTI and C4. Not sure about CQC. I agree that decoupling the temp sensor is a really good idea (there are C4 thermostats have this too) could I use a Lutron detached temp sensor in conjunction with the Venstar? And if I use a non-Lutron thermostat can I also incorporate SeeTemp controllers, or do I need a Lutron thermostat to use SeeTemp?
Lots and lots of great info here. Thanks so much guys!
Bottom line is yes, in selecting my components I do need to be sure I'm selecting products that are cross-compatible. So while I may not have to make the final automation decision now I do still need to figure out what will work with all three systems.
A lot of this thread has been CQC oriented but I'm looking for something that will work across the board. Sounds like on the alarm side HAI/ELK/DSC is the way to go. Is there a clear #1?
The RTI guys want to use RTI gear for audio distribution and the C4 guy wants to use C4 gear. Russound and Nuvo are popular third party options. Would that be the way to go to keep things compatible across the board and is there a clear #1?
For online streaming music I want to use Sonos because it works with the most services. I know Extra Vegetables makes a Sonos driver for C4 and RTI just came out with a Sonos driver. Any way to integrate Sonos into CQC?
