Perpetual Elk Rule Conflicts
mstarks01
I have a problem with my Elk M1G. Every time I connect I get an alert saying that there are two conflicts: one with rules and one with texts. I select all and send to the system and it clears it for the session, but the next time I connect there is the same message.
I created a new default account and imported everything from the M1G thinking that I needed a fresh start and that would clear it up. Surprisingly, it didn't. I have some rules that aren't working and I suspect this is the reason. The rules/texts cannot be viewed or deleted. How can I get rid of these conflicts? Thanks.
I have the same issue. I'm pretty sure in my case it is do to a couple of disabled rules so i've been ignoring (though that doesn't explain the texts one being flagged)
I have had the same problem here, for years. I never did figure out why, just haven't put much effort into troubleshooting this.
I don't know why but it occurs with disabled rules (and maybe comments too, don't recall). Like all the others, I either ignore it or send it to the system. Try enabling any rules that are disabled and see if it goes away.
This is indeed the reason why it reports a conflict. I have had this confirmed by our local Ness (Aussie ELK) folks here. Either enable or delete the disabled rules and no conflicts will be reported.
I have some rules that I just enable and disable from time to time so I choose to keep them and simply select the Text and Rule and then send to system.
RP is about to go through a major upgrade in January maybe this issue will be address.
Regards,
Fleetz
I had major problems with this and for a long time it went away... I'm not sure if it was related to what I did or not... but.
I decided to receive all from the control and then send all back to the control, and it seemed to go away. unless something else happened ?!?!
