The tone of this thread is definitely unfortunate because I would really like to know the reasoning against using PVC plumbing "conduit" for low voltage wiring and whether it is really "against code" or just "bad practice". I have used white PVC for runs before (just in my own home, I am no pro) mostly because the selection for electrical conduit at the home center isn't very complete. Is color just to be able to determine what is plumbing and what is low voltage wiring?
The electrical conduit has UV inhibitors in it's formulation. While PVC conduit in Arizona or Florida sunlight will tend to get brittle, those are extreme examples. I can't go into what's involved and/or contained in the UL listings, because it's not what's important, but the main thing that always gets brought up is it is listed for it's purpose, which is electrical wiring, so obviously there's some testing and other items done which plumbing pipe has not gone through.
There's a reason to not use plumbing fittings, which is they don't maintain the bend radius for cabling, as well as being almost impossible to run a snake through for fishing wiring. Same reasons why you shouldn't have more than 4 90's in a pipe run and the formulas for conduit fill....not just for heat dissipation on HV conductors or to make the runs more difficult. As far as being against code, mechanical protection or not,the AHJ's in my state would fail the install, as well as if something were to happen and insurance underwriters were involved....they would walk away from any claim because of the violations, which I have seen happen before on fire AND burglary jobs installed by others in such manners. May not be an issue with the majority of the CT forum, as I think getting the installs inspected and signed off on aren't commonplace, unless it's different in other areas of the country altogether.
I'm not mentioning the old HV installs and some LV installs around here where the wiring is actually inside black iron piping, which was the original gas piping in a lot of these houses prior to a complete electrical install and modified when the homes were electrified.
As far as Zigbee and the contemporaries go (Zwave, etc.), I am limited to what the manufacturers use as their protocols for RF remote control interfaces....AMX, Crestron and others. I didn't pick it, I'm just limited in what I can run wiring for when a system isn't completely specified out of the box, because if I knew they were going with Crestron, then I could pull Crestron cable, otherwise I have to do my best to anticipate and be able to adapt the wiring after the fact, so I'm stuck running a siamese Cat6 for "control" of the TV's at the moment. Same reason why I'm stuck running component video using MAC-6....HDMI baluns are only good for a certain distance, then after that you've got sync issues or the resolution gets kicked down to 1080p or lower because of the lack of bandwidth. Would I love to get away with pulling less cabling and less heavy stuff, you bet, but I'm limited to what's on the market.
Work- I've had more "engineers" and engineer types talk down to field techs because of their views of superiority in their knowledge of how something works, how to make it work, etc. so honestly, I find the holier than thou attitude to be the exact reverse. There's engineers and then there's what I consider myself to be, a specialist in low voltage wiring, installations, and integrations. I relate it as a Dr. vs a surgeon. The Dr. can tell you how something is supposed to be done, and while technically they can perform the surgery, I know I'd rather have the surgeon doing the specific consult and the procedure as they have the practical knowledge and experience specific to the procedure to be performed and how to perform it.
My favorite (off topic) story of this is a electical engineer that was modifying their network in the house we were LV contracting in. They lost their IP connection across the board and the blame was everyone else that was there....us, the ISP, the modem manufacturer, the cabling, the fiber attenuation...everything. I had great pride in taking their network rack apart to find that this guy took his HDSL filter and filtered out the net off his lines himself...then was tagged on to his neighbor's wifi connection for about a year or so while the house was being final'ed, until the neighbor locked down their net. I had great pride in providing the network certifications and documentation from the Fluke as well as the pictures of his "modification/improvement" and the nice bill for certifing the cabling within the house (his request/rant). All the while he got a "yes Mr. XXX" because of we were "playing" where he's clearly the expert.
