IVB
YOu need 18-2 for power, coax for video. I got a combo from tselectronics.com for a mediocre price so I only have to pull one cable. You can also pull CAT5 and use video baluns on either side, but that'll be $13-$25 per balun.
Camera uses BNC for video, some regular plug thingey for the power. I got these adapter thingeys from RadioShack for that, pretty cheap. I also got BNC screw-on connectors from RadioShack for the coax part. My PCI card also needs BNC, so I need that on both ends.
For power, I got something like a 1.5A 12VDC power supply, and one of the Elk power distributors [Elk PD9? running to a parade now, will look that up later]. It takes the power supply as input, and you can tie the 18-2 directly into that.
I also got a variety of .25A fuses from RAdioShack that i'll be putting in shortly, to make sure nothing happens and takes out all the cameras.
