PIR Motion Corner Bracket Suggestions
Sacedog
I purchased a few GE PI6000 motions, and am looking for suggestions on which brackets I should use with them. I found these searching on Google, but I wonder if anyone has any experience with them. If not, is there a bracket that you would suggest?
http://www.smarthome.com/7481b2.html
If you are using the PIR for its pet immunity feature check the literature. Some PIR's don't allow you to use a bracket of any kind for pet immunity. If that is not the case I'm not sure why GE doesn't make a bracket for it.
do you need adjustable?
my PIRs had a 45deg angle on each vertical edge (together equaling 90deg) only 3/8 or 1/2" wide, that had 'knockouts' (really 'push-throughs' as you just use a screw to open the hole in a thin spot in the plastic) which allow for corner mounting . .
from the few pics I can find (none had a good angle to see the top/back) of your GE PIR it looks like it has the same feature . .
