my omnistat2 sits in a hallway outside our bedrooms. when all the doors are closed and the heat is running, the temperature read by the thermostat can be 4-5 degrees off of that in the bedroom. i'm experimenting with the Heat anticipator settings on my omnistat but i'm also planning to install a few remote temp sensors (HAI 23A00-2 Flush Remote Temperature Sensor) throughout the house, 3 in bedrooms and 1 in my living room.
I'd like to install these sensors in locations as inconspicuous as possible. is it inadvisable to put these in the ceiling? if i put them in a wall, what's a reasonable mounting height? can i get away with putting them up high? obviously heat rises but i'm not sure how much accuracy i'd be giving up if i mount the thermostat up higher in the room.
advice appreciated, thanks!
