INSTEON uses Modulation: Binary phase-shift keying (BPSK) at 131.65 KHz which is away from our 110KHz FSK system. We have not done any testing at SolarBridge but it should work well due to difference in frequencies. We originally based our technology on ST microsystems, but have made improvements since then.
Homeplug is used all the time as the last 300 feet solution to get the Power Manager’s (the monitoring system) ethernet signal to the home router. The Power Manager and Homeplug system are connected side-by side and work very well. In fact SolarBridge recommends using www.asokatech.com PLC devices because they have a device tailored for solar. The SolarLink version (
http://www.asokatech.com/solarlink-page) operates down to -20C which means you can use it in an unheated garage. The Power Manager is NEMA 3R and can be mounted outside or in an unheated garage. No other solar monitoring system can do that without an external enclosure.
As with all technologies, the right installation is key for a 25year lifespan. Physical separation of the solar combiner box will reduce any problems.
One thing,INSTEON-RF uses the same frequency as my pool automation. However, PLC systems are closed-systems (in house wiring) and therefore separation (and filtering if needed) will absolutely separate solar and home PLC communications for the 25 year warranty life of the solar system. The fact there is a solution path if needed is great!
Finally, do not demand filtering at the start of the design, SolarBridge as has to use filtering just a few times. Just use separation and you have room for a filter if it is ever needed.
